Thread: Integrating components into living room decor |
New member Username: N9949y
Eugene,
OR
US
Post Number: 2 Registered: Dec-07
| Posted on Thursday, December 27, 2007 - 02:08 pm: |
So that all my components wouldn't be my spouse's eyesore I designed a 3 part module built by a local furniture maker. The module set up allows easy access to rear of system. Rear and surround speakers are hidden behind furniture along fireplace wall.
Relevant Product Info
Eugene,
OR
US
Post Number: 3 Registered: Dec-07
| Posted on Thursday, December 27, 2007 - 02:17 pm: |
Components re: the above system: TV-Monitor, DLP, LG RU-44SZ63D Receiver- Rotel RSX 965 Laser Disc Player- Pioneer CLD 1080 Field Sound Processor- Yamaha DSP E300 Comcast Cable- Motorola DCT6200 Tape Deck- Kenwood Double KX-W5040 DVD Player, Hi Def-Progressive - Onkyo DV-CP702 Graphic Equalizer- Pioneer GR-555 CD Player- Fisher DAC 195 VCR, Hi-Fi - Panasonic PV-4021 VCR, Hi-Fi- JVC SQPB Turntable/Changer- Garrard Zero 100 Sub Woofers, 2 –Yamaha, powered YST-SW100 & YST WS-205 Speakers, 4, Paradigm Titan (2 for Rotel main fronts, 2 for Yamaha DSP front effects) Speakers, 2 Dynaco A25 (Rotel rear effects) Speakers, 2 Acoustic Research 18S, (Yamaha rear effects) Speakers, 2 Realistic Minimus 7W ( Yamaha DSP Center, Rotel Center) AC Voltage Activated Outlet Switch, Niles AC-3 Head phones, Sennheiser HD280 Pro |
Silver Member Username: Huron
Post Number: 333 Registered: Mar-07
| Posted on Friday, January 04, 2008 - 02:22 am: |
thats a pritty good hiding job is that one of them next to the window? nice room and the TV and equipment stand look very nice, weres the center channel? |
Silver Member Username: Deadhorse
Post Number: 106 Registered: May-06
| Posted on Friday, January 11, 2008 - 09:41 am: |
Looks very nice but could you explain your front speaker setup? I see what looks like two taller speakers on the left, two bookshelf speakers on the right and two small speakers on either side of the center divide, I'm confused? |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 543 Registered: Feb-07
| Posted on Monday, January 14, 2008 - 11:02 am: |
Nice setup, very clean. Don't you find though the sound quality is not optimal since the speakers are so close to the floor? The tweeters should around ear level relative to your seating position. |
Bronze Member Username: Amish
Riverside,
CA
Post Number: 38 Registered: Jan-08
| Posted on Wednesday, February 20, 2008 - 07:16 pm: |
I think Todd is confused as well when it comes to proper speaker placement. Nice entertainment center if not a bit crowded. |
