Home > Message Board > Home Theater > Home Theater Speaker Packages > Front Speaker recommendations
Author Thread: Front Speaker recommendations
Username: Lordderth
I have a Yamaha 7.1 Channel HDMI Receiver (HTR6080) with PSB Alpha Mini and a Mirage P58 for a 5.1 system with Sony 1080p 52" Widescreen LCD HDTV BRAVIA (KDL52XBR4). I am planning to slowly upgrade the speakers starting with buying two towers. What would be a good choice? PSB Image tower T65? What about Poke (RTiA5) or Klipsch (Synergy Series F-2), Infinity Beta 40 3-way or Energy Reference Connoisseur 3-way RC-30?
How important is voice matching? I read one place that indicates if I am using the speakers more for movies and HD TV then it is not as essential as for music. I do not want to change all five speakers now.
Current room size is not too large but I am planning a move and could end up with a larger room for the home theatre.
Relevant Product Info
Username: Gavdawg
Upstate, New York
Post Number: 1016
personally, I would not pair Klipsch with Yamaha... bright sounding speaker with bright sounding receiver. Odds are, you wouldn't like it for very long
Username: Lordderth
Thank you Gavin for your help!
How about the Polk with my existing PSBs and Mirage subwoofer?
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Home Theater Speaker Packages > Front Speaker recommendations [ « Previous ] [ Next » ]
