Home > Message Board > Home Theater > Home Theater in a Box > Bose 3-2-1 Troubleshooting question
Author Thread: Bose 3-2-1 Troubleshooting question
Username: Nyi8083
Hey all- This is my first post over here and I'm just hoping that someone can give me a little help. I've tried searching for a post involving a similar issue to mine but had a bit of difficulty navigating the search system.
I recently purchased a Bose 3-2-1 GS Audio system for my home to replace a 5.1 system that had run into a few problems. Now as it turns out, I'm having a bit of trouble getting my new system to work.
My problem comes when I'm watching TV and I change channels. There is a sort of pop/static noise as the channel changes more or less every time. I'm hoping that someone here could help me by pointing out any likely origins of this kind of problem,
Is this something that is most likely stemming directly from the unit? or is this more likely something that is a result of the cabling and maybe some loose connections? Maybe something else?
Thanks, I appreciate any help-
Relevant Product Info
Username: Yurired1
Canberra, ACT
Australia
I would check the connectors first to eliminate them as a suspect. However, I had a similar problem to your's two weeks ago. I'd be watching TV and for no apparent reason, there would be a loud pop and the sound volume would drop. The volume wasn't particularly loud. Then, my fiancee noticed that it only happened when we were watching something on pay TV (our version of US cable). Turns out it's a superceded decoder and I'm now awaiting a new set-top decoder box.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Home Theater in a Box > Bose 3-2-1 Troubleshooting question [ « Previous ] [ Next » ]
