Home > Message Board > Home Theater > Home Theater in a Box > Input/Output Question
Author Thread: Input/Output Question
Username: Jtufnell
Dallas, Texas
Total novice here...I am looking into purchasing an HITB system with a budget of $400. One thing I worry about is not having enough input/outputs since many reviews of budget HTIBs say they lack inputs/outputs. How many inputs/outputs will I need to connect with an HDTV, Blu-Ray DVD, and X Box? What are the best types of connections?
Username: Jtufnell
Dallas, Texas
Oh...I forgot...I also have a cable/dvr box.
Username: John_s
Columbus, Ohio
US
Post Number: 1935
In a pinch, the HDTV will have enough video inputs, and you would want enough inputs to accomodate the digital audio outputs of your stuff---Blu-ray, xbox, and cable box. As you say, most cheap HTiBs don't have that many.
A better situation would be to have a real audio/video receiver (AVR) so that it could act as the "hub" of your system. That's why I like the Onkyos. Check this out for $420.
http://www.vanns.com/shop/servlet/item/details/502499668
And to think they charge $4000 for this.
http://www.vanns.com/shop/servlet/item/features/501999861
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater in a Box > Input/Output Question [ « Previous ] [ Next » ]
