Thread: Issue with surround sound |
New member Username: Leston22
Post Number: 3 Registered: Nov-07
| Posted on Monday, November 12, 2007 - 11:49 am: |
okay so I installed a whole surround system, yamaha amp, and when I play the FM tuner, all speakers sound good. However, when I play the TV (Sharp Aquuos 52) only the front speakers and the subwoofer sounds, leaving out the rear speaker and the center. The hd direct tv reciever is connected directly to amp. Any idea on what could be the issues? |
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 442 Registered: Jun-05
| Posted on Monday, November 12, 2007 - 03:00 pm: |
How are you connecting the direct TV to the receiver, HDMI, Digital or Optical cable, composite (yellow) cable? Have you done a proper setup with the receiver and the cable box? You may have to configure the digital input on the receiver and the digital out put on the cable box. |
Post Number: 4 Registered: Nov-07
| Posted on Tuesday, November 13, 2007 - 08:15 am: |
im connecting the hdmi reciever to the tv, and the red, yellow and white cable to the amp... thats what I was told I should do |
Bronze Member Username: Floyd_1977
Plainfield,
IL
Post Number: 94 Registered: May-06
| Posted on Tuesday, November 13, 2007 - 10:18 am: |
Connect your DirecTV receiver to your amp using an optical cable. That way, you'll be able to get true surround sound from programs that offer it. I'm not sure who told you to use analog cables, but as you have it hooked up now, the best you will be able to do is Dolby Pro Logic or some other DSP (or stereo obviously). As Casey said, once you've hooked up your receiver with an optical cable, you still may need to adjust your DirecTV and Yamaha settings, according to your manuals, to get digital sound. |
New member Username: Henry33
Portland,,
OR
US
Post Number: 2 Registered: Nov-07
| Posted on Monday, November 19, 2007 - 02:20 am: |
Hey, HT fans - I'm looking for a new home for my Integra DPS 10.5 Universal Disc Player. Great shape, org. box, manual etc. Google the rave reviews of it everywhere. SRP was $2500; I'm asking $1400 plus shipping. Contact me at scriabin33@aracnet.com |
