Home > Message Board > Home Theater > Surround Sound > Question about surround sound, optica...
Author Thread: Question about surround sound, optical audio cables and component cables
Username: Evan04
My TV has an optical audio output.
So if I have my DVD player hooked up to the TV via HDMI cable, then run the optical audio out from my TV to the surround sound receiver, will I be receiving true dolby surround sound?
Next question, my cable box does not have an HDMI output so I have that hooked up to the TV via HD Component cables. That can’t carry Dolby Digital correct? So I need to run another optical audio cable from the cable box to the Surround Sound Receiver to achieve true surround sound, right?
Relevant Product Info
Username: John_s
Columbus, Ohio
US
Post Number: 1868
"My TV has an optical audio output.
So if I have my DVD player hooked up to the TV via HDMI cable, then run the optical audio out from my TV to the surround sound receiver, will I be receiving true dolby surround sound?"
That optical output on your TV operates only when your display receives a digital over-the-air broadcast signal via a normal antenna. The TV will not send out any audio signal sent in on its HDMI input. You'll have to send the digital audio from your DVD player directly into your receiver.
"Next question, my cable box does not have an HDMI output so I have that hooked up to the TV via HD Component cables. That can’t carry Dolby Digital correct? So I need to run another optical audio cable from the cable box to the Surround Sound Receiver to achieve true surround sound, right?"
Component carries video only, so yes you'll have to run a separate digital audio connection from cable box to receiver.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Surround Sound > Question about surround sound, optica... [ « Previous ] [ Next » ]
