Thread: Pioneer VSX-517 help |
New member Username: Ssscmike
Post Number: 1 Registered: Oct-07
| Posted on Monday, October 29, 2007 - 01:23 am: |
I just purchased the Pioneer VSX-517 receiver to play my xbox360 in 5.1, but now I am curious if I am able to play my TV through the surround sound. I have my xbox hooked up to the DVR/VCR slot, and it works fine, my DVD player hooked up to the DVD/LD slot, working fine, and my TV hooked up to the TV/SAT slot, but it does not put out any sound at all. Anyone have any suggestions? |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 365 Registered: Feb-07
| Posted on Monday, October 29, 2007 - 07:28 pm: |
What do you have for your TV source? Cable? Satellite? |
Silver Member Username: Huron
Post Number: 304 Registered: Mar-07
| Posted on Monday, October 29, 2007 - 09:11 pm: |
all audio sources get hooked up to the receiver, if you have any audio sources hooked up to the TV unhook them and hook them up to the receiver |
Ottawa,
Ontario
Post Number: 367 Registered: Feb-07
| Posted on Monday, October 29, 2007 - 09:13 pm: |
Thanks Angelo, that's what I was getting at... |
Post Number: 305 Registered: Mar-07
| Posted on Monday, October 29, 2007 - 10:05 pm: |
I know, I thaught it would be funny, sorry |
Post Number: 2 Registered: Oct-07
| Posted on Tuesday, October 30, 2007 - 03:01 am: |
The TV is plugged right into the receiver, nothing else hooks into the TV, I have satellite provided by Dish Network. But they hooked it up so that the box is in the living room, and my room uses IR/UHF to control the box. I should mention that when I turn the volume all the way up on the receiver, I can hear the TV very very quietly, but its fuzzy as hell. |
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 435 Registered: Jun-05
| Posted on Tuesday, October 30, 2007 - 03:05 pm: |
Your Dish Network box is in another room, Ive seen this before. Normally the Dish box audio out would be hooked up to the receiver. Either move the cable box to the room with the receiver or get a HI-FI VCR and hook it up betwen the Dish box and the TV and send the audio from the VCR to the TV. |
Post Number: 3 Registered: Oct-07
| Posted on Tuesday, October 30, 2007 - 06:30 pm: |
So if I hook up from the TV to the VCR, then from the VCR to the receiver it should work? Or are you saying hook up the VCR to the Dish DVR box, then run cables from that VCR to my receiver? I appreciate the help. |
Ottawa,
Ontario
Post Number: 378 Registered: Feb-07
| Posted on Friday, November 02, 2007 - 10:03 am: |
Why not just buy an extra long RCA audio cable (from Radio shack) and run it from the satellite box to the receiver? |
