Home > Message Board > Home Theater > Surround Sound > Sony receiver help needed with subwfr...
Author Thread: Sony receiver help needed with subwfr detection
Username: Poochi425
Mis, On
Post Number: 37
Hi All
I bought the sony rcvr recently and worked fine for a week or two but then all of a sudden the recvr. fails to emit any sound from the sub.
I even tried going thru the test-tone menu but all the other spkrs pass the test tone test but nothing comes out of the subwoofer. dunno why ?
what caused it ?
may be the settings ? i went thru the manual, tried every possible setting but no result...
Took it to the sony service depot, they were not helpful at all instead had a big yellow sticky posted on the box saying: please follow the instructions in the manual, no fault found but won't specify what settings to use or what may have caused the subwoofer to go quite.
i would really appreciate everybody's input on this.
p.s. i'm using regular rca audio cables for connections.
thx
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Surround Sound > Sony receiver help needed with subwfr... [ « Previous ] [ Next » ]
