Home > Message Board > Home Theater > Surround Sound > Is it possible to use regular rca cab...
Author Thread: Is it possible to use regular rca cable for coaxial audio
Username: Poochi425
Mis, On
Post Number: 36
i'm just wondering that :
is it possible to use regular rca cable for coax audio input ??
as i just tried it with my sony rcvr and the front panel does light up saying digital input.
but i just need to know if it turned-off my subwoofer as now i don't get any sound from the sub.even test tone doesnt work.
plz help
Relevant Product Info
Username: Mccambley
BREEZY POINT, NY
Post Number: 436
Unplug the digital connection and go back to anolog and see if the sub works. It did not turn off you sub, if your sub still does not work check your connections and your subs power.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Surround Sound > Is it possible to use regular rca cab... [ « Previous ] [ Next » ]
