Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 21, 2007 > Polk PSW10 vs Velodyne VX-10
Author Thread: Polk PSW10 vs Velodyne VX-10
Username: Whiteskull666
Whic of these should i buy ?
my room is approx 15x 15 ft.
and budget low.
Polk PWS10
[URL="http://www.polkaudio.com/homeaudio/products/individual/subwoofers/psw10/"]http://www.polkaudio.com/homeaudio/products/individual/subwoofers/psw10/[/URL]
Velodyne VX-10
[URL="http://www.velodyne.com/products/product.aspx?ID=8&sid=714v429c"]http://www.velodyne.com/products/product.aspx?ID=8&sid=714v429c[/URL]
Thnx !
Username: Mvanmeter
KY
Post Number: 131
if you sort through the many reviews on the web, I think you will find better reviews for the Velodyne.
You may wish to check out subs at www.hsuresearch.com and www.av123.com
generally better than either Polk or Velodyne
Username: Huron
Post Number: 297
a lot of people in hear use velodyne but martin is right, subs are a expense so do you research
Username: Dmitchell
Ottawa, Ontario
Post Number: 364
I actually have both of those subs. They're both good in their own ways... I use the Polk in my HT setup (I actually run two of them), and I use the Velodyne in my 2-channel setup. The sensitivity on the Velodyne is very low. I had to crank up the volume on the sub to full to get a satisfying level of bass. That being said, the Velodyne is tight, fast sub.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 21, 2007 > Polk PSW10 vs Velodyne VX-10 [ « Previous ] [ Next » ]
