Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 21, 2007 > Denon AVR-1507 vs Onkyo TX-SR505
Author Thread: Denon AVR-1507 vs Onkyo TX-SR505
Username: Whiteskull666
I am planning to geta home theatre system for my new house.
am new to hookin up home theatre systems, keeping my budget pretty low.
im thnkin of gettin
Denon AVR-1507
www.usa.denon.com/ProductDetails/3252.asp
or
Onkyo TX-SR505 receivers.
www.onkyousa.com/model.cfm?class=Receiver&m=TX-SR505&p=i
which one do i buy ?
both look equally attractive.
And which speakers would you recommend ?
was thinkin oh hooking up Polk RM6750
www.polkaudio.com/homeaudio/products/rm6750/
or maybe Bose Acoustimass® 6 speaker system
www.bose.com/controller?event=VIEW_PRODUCT_PAGE_EVENT&product=am6_surround_index &ck=0
PLease advice !
thnx !
Username: Mccambley
BREEZY POINT, NY
Post Number: 428
You can do better with the speakers, both receivers are fine for the money. http://paradigm.com/en/paradigm/fronts-cinema-series-1-2-2.paradigm http://paradigm.com/en/paradigm/fronts-monitor-series-1-2-4.paradigm
Username: Mccambley
BREEZY POINT, NY
Post Number: 429
One approach that you could take is to only buy the front L&R speakers and wait till you have more money for the rest of the speakers. Paradigm Atoms are $250 a pair, the PDR-8 subwoofer is $300. If you can get slight discount say 10% and a little more money you could get a much better speaker setup.
hey casey !
thnx for the gr8 idea of jus gettin 2 speakers for now..
bt can i hook up just 2.1 speakers (FL/FR/Sub) to a 5.1 ch amplifier and add the others (SL/C/SR) later? it that possible?
will i get virtual surround sound ?
Username: Mccambley
BREEZY POINT, NY
Post Number: 430
You can hook it up and play back your movies in stereo for now. The sound will not be surround sound but it will be better than the TVs sound and great for music play back. When your ready for the next step in building you system get the back speakers first for surround sound and add the center last. In a set up with no center speaker tell the receiver there is no center and it will put the diolog in the front L&R speakers.
Username: Mccambley
BREEZY POINT, NY
Post Number: 431
Personally I am a Denon fan.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 21, 2007 > Denon AVR-1507 vs Onkyo TX-SR505 [ « Previous ] [ Next » ]
