Home > Message Board > Home Theater > Home Theater in a Box > Home Theatre connection to TV - Basic...
Author Thread: Home Theatre connection to TV - Basic Cable
Username: Ddzc
Hey guys,
I have a home theatre here with a basic cable. I have it hooked up to my xbox with the digital optical but I want to hook it up directly to my TV. How can I do this without a digital cable receiver?
This is my home theatre receiver:
http://i3.photobucket.com/albums/y92/ddzc/uio.jpg
Thanks
Username: John_s
Columbus, Ohio
US
Post Number: 1856
If your TV has audio output jacks, you can get TV audio by hooking them up to the HT receiver.
If that's not the case, you could also use the audio outputs from an external device such as a VCR or DVD recorder with built-in tuner.
If you want digital surround like your xbox gives you, then you'll have to bite the bullet and get a digital cable box.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater in a Box > Home Theatre connection to TV - Basic... [ « Previous ] [ Next » ]
