Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 21, 2007 > How do I setup to get local HD channe...
Author Thread: How do I setup to get local HD channels with my plasma
Username: Marionr26
Charleston,sc
I have the built in tuner in my tv so should I automatically get hd local channels. Do I have to set it a certain way. I still use my over the air small ant. to get local HD channels. I want to unhook it and use my HD tuners in my Plasma...How do I do that???? Im using Direct tv.
Username: John_s
Columbus, Ohio
US
Post Number: 1855
Rod, the HD tuner in your display needs an antenna to work. You can't unhook the antenna and expect the same reception of your locals to continue unchanged.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 21, 2007 > How do I setup to get local HD channe... [ « Previous ] [ Next » ]
