Thread: N00b-correct setup? |
New member Username: Audiogreenhorn
Post Number: 1 Registered: Oct-07
| Posted on Wednesday, October 17, 2007 - 07:29 pm: |
First off, I have a "starter" system. A Sony 32" HDTV with 1-DVI port and a Sony 5.1 receiver/DVD combo but regular Direct TV not HD. If I upgrade to HD, would you connect DVI from TV to HDMI out port on receiver? Then connect component video in from satellite box to component video out on receiver? I assume I would have to also run optical from TV to receiver for sound? I'm really a n00b at this. |
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 1847 Registered: Feb-04
| Posted on Wednesday, October 17, 2007 - 10:18 pm: |
Hey Shane, it's OK we all start somewhere. "If I upgrade to HD, would you connect DVI from TV to HDMI out port on receiver?" Yes. "Then connect component video in from satellite box to component video out on receiver?" Aaahhh, NO! Why would you want to send any video signal from the receiver into the sat box? "I assume I would have to also run optical from TV to receiver for sound?" No, the optical out on the TV is there only if you receive a digital signal via the TV's antenna input with the TV's over-the-air tuner. What you should do is send the satellite box's digital signal (optical or coax) into the Sony receiver. Good luck. |
Post Number: 2 Registered: Oct-07
| Posted on Thursday, October 18, 2007 - 07:18 am: |
OK. So DVI goes to HDMI port. So what do I connect my satellite box? Receiver or TV? |
Columbus,
Ohio
US
Post Number: 1850 Registered: Feb-04
| Posted on Saturday, October 20, 2007 - 09:44 am: |
Shane, let me back up a little here and change something I said above. There's always more than one way to hook up audio/video components. All I can tell you is what I would do. Also making suggestions is a little difficult because without model numbers, I can't be sure what hookup terminals are available on your equipment. 1. Connect the DirecTV HD receiver's HDMI output directly to your TV's DVI input using an HDMI to DVI cable. There is a possibility of a compatibility problem, even though HDMI is supposed to be backward compatible to DVI. This hookup will work or it won't. You'll know right away. If there is a problem you can fall back to running component lines from the sat box to the TV. Just don't spend too much money on that HDMI cable. http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10231&cs_id=1023102 &p_id=2218&seq=1&format=2 2. Connect the sat box's digital audio output into the Sony receiver as I said above. 3. Connect component video cables to the TV from the Sony so you can take advantage of its progressive scan DVD playback. That's it. You will have to switch inputs on the TV between the satellite box and the DVD player. I think the DVD player will over ride the sat box's audio feed when you start a DVD, or you might have to switch inputs on the Sony receiver as well. Check your owner's manual on that question. |
