Thread: PLAY IT LOUD! HELP ME! |
New member Username: Rockit32
Post Number: 1 Registered: Oct-07
| Posted on Friday, October 12, 2007 - 01:19 am: |
I'm looking to set up a system in my apartment. However, I can not decide what type of system to get. I want a good set of speakers and a receiver that i can watch movies and stuff with, but the main purpose is for music. I cant decide if i should get bookshelf and surround speakers with a sub, or just two big floorstanders. I plan on having people over almost every weekend and I live in a college town so the louder the better. I also work at Best Buy and get a good discount on Klipsch. What should i do? |
Silver Member Username: Huron
Post Number: 243 Registered: Mar-07
| Posted on Friday, October 12, 2007 - 02:54 am: |
if you want the music loud and cut threw all the crowed noise Klipsh is a good choice, http://www.hometheatersound.com/equipment/klipsch_reference.htm powered by an H/K 645 http://www.abesofmaine.com/item.do?item=HKAVR645&i=PRICEGRABB to smooth it out when your with a very spankable sexy girl watching a 5.1 movie or music like steely dan Gaucho 5.1 or dark side of the moon |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 345 Registered: Feb-07
| Posted on Friday, October 12, 2007 - 09:11 am: |
If you want loud then Klipsch is certainly a good option, especially if you're gonna get a discount on them. I have a pair of Synergy F2's and I really like them. Just out of curiosity, how much would these run you in your neck of the woods? |
Post Number: 2 Registered: Oct-07
| Posted on Friday, October 12, 2007 - 01:39 pm: |
Im not sure exactly how much i get off, probably somewhere around the area of 30%-35%. are the F2 floorstanders enough to handle the bass or would i need a sub? and what receiver do u have? also i have a question about receivers. If it is rated at say 85 watts per channel for a 7.1 if i put it in surround mode does it boost the watts or would it still remain just 85 watts |
Ottawa,
Ontario
Post Number: 346 Registered: Feb-07
| Posted on Friday, October 12, 2007 - 02:45 pm: |
The F2s push out a respectable amount of bass. I'd say it all depends how big of a room you'll be listening to them in. In an apartment I'd suspect they'd be more than enough. I'm driving them with a NAD 2150 (50 watts / channel - MORE than enough power). |
Post Number: 3 Registered: Oct-07
| Posted on Friday, October 12, 2007 - 08:17 pm: |
ok thanks guys. what do u think of this: Receiver: http://www.harmankardon.com/product_detail.aspx?Region=USA&Country=US&Language=E NG&cat=REC&prod=AVR%20247&sType=C Floorstanders: https://www.klipsch.com/products/details/rf-62.aspx Center Channel: https://www.klipsch.com/products/details/rc-52.aspx i think i should get a center channel because i know those are good for movies. but im new at this and if u guys think i could save some cash if i dont need one let me know. thanks in advance |
Ottawa,
Ontario
Post Number: 348 Registered: Feb-07
| Posted on Friday, October 12, 2007 - 08:27 pm: |
The RF's beat the F2's hands down. If you're serious about watching movies then the center is a good idea. It's a good idea to buy one that matches your fronts. |
