Thread: Wiress Speakers |
New member Username: Ableman2
Post Number: 3 Registered: Mar-07
| Posted on Wednesday, October 10, 2007 - 11:28 pm: |
Any wireless speakers systems that can support 3 speakers? Sean |
Silver Member Username: Mvanmeter
KY
Post Number: 130 Registered: Jan-06
| Posted on Friday, October 26, 2007 - 10:16 am: |
not that I have seen and, ultimately, you will be disappointed with wireless speaker systems regardless of what you get. Too much interference from other RF sources in the home and generally "crappy" sound. Running wires, even it is just pushing the wire under toe moulding and along the edge of carpet, or using new "flat cable" under carpets is FAR supeior to anything you will get with wireless speakers |
Silver Member Username: Huron
Post Number: 298 Registered: Mar-07
| Posted on Saturday, October 27, 2007 - 01:56 am: |
wireless, yuckky |
