Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 21, 2007 > Need Reccomendations
Author Thread: Need Reccomendations
Username: Auburnfan
Washington , DC
I just bought 4 Polk R50s. Still need center channel and sub, not to mention Receiver. This is all for my Mits 73-833 DLP. Need to know what center channel matchs up well with these speakers and which sub. I am not someone who can probably tell the difference between a thousand dollar sub and a 100 dollar sub. Just want it to sound pretty good and look pretty good. Thanks
Username: John_s
Columbus, Ohio
US
Post Number: 1829
You've already bought Polk. Stick with that brand for the center and the sub. But make no mistake, even a half-deaf person can hear the difference between a $100 and a $1000 sub.
Any current model $300-$500 AVR will run that setup OK.
Username: Sobeeatch
Post Number: 12
John is right. There will be an obviously audible difference between an inexpensive sub and a decent one. Don't undersell your ability to hear it. I also think his price range for a sub is reasonable. If you get one of the cheapies, much of the sub's potential impact will be lost. I'm not just talking about volume but distortion and the capacity to reproduce the lower ends.
Username: Auburnfan
Washington , DC
Thanks, I was kinda hoping for a model specific center channel. I read on some other forums that the csi25 from Polk would work well with the R50s. I guess I am trying to get some confirmation before I pull the trigger.
Username: John_s
Columbus, Ohio
US
Post Number: 1830
The Polk CSR should be good too, especially since it is an "R" series like your towers. Both the CSi25 and the CSR carry the same list price and similar specifications. I would buy the one you can find cheapest.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 21, 2007 > Need Reccomendations [ « Previous ] [ Next » ]
