Thread: Need Help with Home Theatre Connections |
New member Username: Bub12
Bville,
WV
Post Number: 8 Registered: Mar-06
| Posted on Wednesday, September 19, 2007 - 10:52 am: |
I need help connecting my new Hitachi HD 1080i TV to a Pioneer A/V Reciever, Phillips DVD/VCR Combo, a Satallite Reciever, and a PS2. I want to be able to have surround sound for everything, but only when i want to! I want sound thru my speakers in the TV, but also thru the Surround sound when i want, but NOT all of the time if possible. Below is a list of what I have: 2076_4153_60702323%2C00.html,http://www.pioneerelectronics.com/pna/product/detai l/0,,2076_4153_60702323,00.html http://www.epinions.com/pr-Philips_DVD750VR_DVD_VCR PS2 Dish Network Satallite Receiver Thanks!}} |
Bronze Member Username: Floyd_1977
Plainfield,
IL
Post Number: 85 Registered: May-06
| Posted on Wednesday, September 19, 2007 - 02:19 pm: |
HDMI from the Dish box to your HDTV digital optical from your Dish Box to your Pioneer digital audio (optical or coax) from your DVD/VCR to your Pioneer component video and analog audio from your DVD/VCR to an input on your HDTV use y-cables to split the audio from your PS2, and send one signal to your HDTV and one to your Pioneer video from your PS2 to an input your HDTV (the same one you sent the audio signal to in the above step) I believe this is the best way to connect everything if you insist on being able to use your TV speakers without having your receiver on. It's much simpler to just always use your surround system. |
