Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 21, 2007 > Component cable for Sharp Aquos 46" L...
Author Thread: Component cable for Sharp Aquos 46" LCD is only showing 480i?
Username: Fuji905
On
Post Number: 11
I just bought a Sharp Aquos 46" LCD HDTV. I hooked the component cable from my sat rec to the TV and the picture is not as good as the s-video or the composite cable. The receiver is not HD but I thought the component cable would still be better. Is there something I have to do to make the picture better? Settings to adjust?
Username: John_s
Columbus, Ohio
US
Post Number: 1787
Are you using true 75ohm cable for the component connection?
Username: Fuji905
On
Post Number: 12
not sure, I'll have to see
Username: Nickelbut10
Post Number: 330
Kris. A Component cable will hardly look any different than a S-Video cable if the receiver and the source are not both High Def. You will want to get a high def receiver and a high def package from your Sat dealer. Cheers.
Username: Samijubal
Post Number: 3508
What kind of satellite receiver do you have that has component out but isn't HD?
Username: Fuji905
On
Post Number: 13
viewsat ultra
Username: Fuji905
On
Post Number: 14
thanks Nick
Username: Samijubal
Post Number: 3510
Component should look better than s-video and definitely better than composite. If it looks worse, you've got a bad cable or a poor quality satellite receiver or something.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 21, 2007 > Component cable for Sharp Aquos 46" L... [ « Previous ] [ Next » ]
