Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 21, 2007 > Help setting up HDMI and dvd recordin...
Author Thread: Help setting up HDMI and dvd recording - Please
Username: Dddon
Hi,
This is probably a really simple setup, but the problem is, I'm a even simpler guy. Can anyone help?
Here's the equipment:
Scientific Atlantic - Explorer 8300HD (cable box)
Sony KDL-46S2000 (tv)
Sony RDR-VX555 (vcr/dvd recorder)
I have Time Warner cable with the HD package. I can record on the cable box and would like to "copy" those recordings to the dvd recorder as well as get the best possible picture whether in HD or regular TV. All three components have HDMI and S-Video connections.
Can someone please suggest the best way to connect this? Thanks
Username: Bill_paul
La Mesa, CA
Post Number: 10
On the assumption that you are a thief with the intent of making hundreds of DVD copies, the video content industry is going to prevent you from doing this.
Any video content from your cable box going through the HDMI interface is encrypted, and furthermore there are no recorders with HDMI input, encrypted or not.
The S-video interface may work, depending if you cable box is outputting macrovision or not. I'm not sure, but I believe with premium channels (anything not broadcast TV), there will be a macrovision signal in the video that tells your DVD recorder not to record, and your DVD recorder will most likely obey that signal.
Try it first with S-video, and if that doesn't work, welcome to being controlled.
Username: Dddon
Really dumb assumption, Bill!
Actually, I'm a parent with 2 young kids, looking to put some episodes of Sesame Street and Mr Rodgers on dvd so my kids can watch them when we go on vacation. The reason I specified HDMI is that the dvd recorder I have says that recording can only be done through the HDMI interface.
Thanks, but no reply at all would have been better!
Username: Samijubal
Post Number: 3511
Either you're reading wrong or the manual is wrong. You CANNOT record from HDMI on any recorder. His post was right on the money. Nice way to respond to someone trying to help. Good luck in the future.
Username: John_s
Columbus, Ohio
US
Post Number: 1793
Byron, that HDMI port on the vcr/dvd recorder is an output....you know, where stuff goes out and nothing goes in---not even Mr. Rogers, rest his soul.
Username: Dddon
John S - Thanks for the reply. As I stated in my question, I don't know much about this.
David M - Won't be any future in this board for me. Bye and thanks to you also.
Bill P - Sorry I used the word dumb. THAT was dumb. Just bothered by waiting two weeks only to be assumed a thief. Again, sorry and thanks for the reply!
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 21, 2007 > Help setting up HDMI and dvd recordin... [ « Previous ] [ Next » ]
