Home > Message Board > Home Theater > Surround Sound > Very much confused!!!
Author Thread: Very much confused!!!
Username: Taeezhoy
Hey, I'm new to this group and was wondering if anyone could help me out...
System includes...
Sony STRDG800
Sony RDRGX355
Phase V4 (x4)
Phase V6 (x1)
Phase FL8 Sub
Well, my buddy who works in an electronic store help me configure my system at my old place but I had to reset the settings when I moved for some reason. Long story short, everything is properly connected, I'm using a digital coaxial to connect the audio BUT the blue multi-channel coding lamp isnt turning on. Message says PCM 48 and doesn't decode the dolby digital feed coming from my dvd recorder/player. Any suggestions would be great! Thanks!
Relevant Product Info
Username: Taeezhoy
jk guys, i figured it out...my rdrgx355 is new and i completely forgot to change the settings for the Dolby Digital and DTS...derr!
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Surround Sound > Very much confused!!! [ « Previous ] [ Next » ]
