Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through September 05, 2007 > Entry Level System - Budget ~ $1000
Author Thread: Entry Level System - Budget ~ $1000
Username: Fusionacid
I am a newbie when it comes to audio. I am starting from scratch and don't own anything but a 42'' sony lcd. What do you guys suggest for a decent audio system for both movies/music for about $1000. My living room size is 30 x 13, so it's long and narrow. Would a 2.1 system be better than a 5.1 for that type of space? The 5.1/7.1 home theater in a box systems at the department stores are not that great and looking for better sound quality. Need advise.
Username: Mccambley
BREEZY POINT, NY
Post Number: 369
Try these for speakers http://paradigm.com/en/paradigm/rec-systems-10-1-2-2.paradigm# and this for a reciver and remember the prices you see are list prices that can be had cheaoer on the street http://usa.denon.com/ProductDetails/3252.asp
Username: Jodymac
Post Number: 8
I have seen alot of good reviews on this system. Polk Audio RM6900 5.1 Channel Home Theater Speaker System, Titanium Finish a few of the reviews said the sub was a little weak.
$549.00 - Wholesale Connection Electronics
At that price I think your getting a pretty good value for a solid system.
I just picked up 2 Front JBL Balboa 30's & a JBL Center.
http://www.jbl.com/home/products/product_detail.aspx?prod=BALBOA30&CheckProduct= Y
What receiver should I get to push these? Also I am looking for a subwoofer. I will buy the rears later.
I researched around and found that the Harmon Kardon receiver w/ JBL speakers are a good match. What you guys think? Which receiver? I would prefer hdmi input/output so i can use this thing in the future.
The speakers state 150W receiver recommended, 80W continuous/320W peak. What about Onkyo, Yamaha, or Denon. Price limit is like $300 to $400'ish.
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through September 05, 2007 > Entry Level System - Budget ~ $1000 [ « Previous ] [ Next » ]
