Thread: 7.1 Speaker suggestions for ~$700 |
New member Username: Soulcougher73
Post Number: 5 Registered: Aug-05
| Posted on Tuesday, May 29, 2007 - 02:21 pm: |
One of my friends is thinking about buying a Bose Acoustimass 10 series 3 setup off of eBay. I know most forums dis on Bose which is why i never bought them. I was wondering if anyone had a better suggestion for roughly $700 for a 7.1 speaker setup. He doesnt need a reciever just speakers. Any ideas of links to nice products would be much appreciated Thanks |
Bronze Member Username: Hodedofome
TX
Post Number: 62 Registered: Dec-06
| Posted on Wednesday, May 30, 2007 - 01:22 pm: |
Couple of choices, lots of folks like the sound of Paradigms, look at the Cinema 70 system and buy 2 more bookshelves for $620 + shipping/tax http://www.paradigm.com/en/paradigm/rec-systems-9-1-2-2.paradigm or http://hsuresearch.com/products/performance2.html You can also do the Mission M70 speakers for a great price http://www.tsto.com/cgi-bin/TSTO.storefront/465da404004d189a2740ac10034105b5/Pro duct/View/2191 The center speaker is the M7C1, you can probably find it on eBay or somewhere. That puts you at only ~$300 for the speakers, so you have $400 to spend on a sub, possibilities are: BIC H-100 http://cgi.ebay.com/BIC-Acoustech-H-100-12-500-Watt-Powered-Subwoofer-NEW_W0QQit emZ140121911135QQihZ004QQcategoryZ3275QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Energy S10.2 http://www.tsto.com/cgi-bin/TSTO.storefront/465da404004d189a2740ac10034105b5/Pro duct/View/2509 HSU VTF-1 (or any of the STF series) http://hsuresearch.com/products/vtf-1.html AV123 X-Sub (you could even buy 2!) http://www.av123.com/products_product.php?section=subwoofers&product=12.1 There's other choices out there, but this should give you an idea what you're looking at. There's a TON of great 5.1 choices for $700, with 7.1 you can do stuff like the Paradigm system or get creative with the others. If you're friend wants a bigger front soundstage he can do something like http://www.tsto.com/cgi-bin/TSTO.storefront/465da463004e56942740ac10034105ff/Pro duct/View/2321 or http://www.tsto.com/cgi-bin/TSTO.storefront/465da404004d189a2740ac10034105b5/Pro duct/View/2639 or http://www.av123.com/products_category_brand.php?section=speakers&brand=55 in the fronts, then do the Mission M70s for the side and rear speakers, then a sub. If you need more explanations of these just ask, room dimensions, speaker size and type of listening (% music/movies) is good info to give. |
