Home > Message Board > Home Theater > Home Theater in a Box > Rear speakers softer than the fronts ?
Author Thread: Rear speakers softer than the fronts ?
Username: Serville
I have Logitech Z-5500 that I use for home-theatre.
My problem is the rear speakers are quite softer than the front speakers. In a real HT setup, aren't they supposed to be equally loud ?
Relevant Product Info
Username: Project6
Post Number: 13843
Depends on the material source and the way the set up is calibrated. But it is not generally as loud as the front, as the rears are used mostly for ambient sounds.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Home Theater in a Box > Rear speakers softer than the fronts ? [ « Previous ] [ Next » ]
