Thread: Home Theater set up... |
| Posted on Friday, May 14, 2004 - 11:00 am: |
hi i'm starting to set up my home theater system. am getting this used sony ES 5cd changer (CS75ES) which is in pretty good shape. any recommendations or advice?? |
| Posted on Friday, May 14, 2004 - 11:18 am: |
Correction: sorry it's C75ES and not CS75ES. |
| Posted on Friday, May 14, 2004 - 04:17 pm: |
What use is a cd changer in a home theater? You'll need a dvd. You are at square one on the learning curve, friend. Best bone up fast.
| Posted on Friday, May 14, 2004 - 05:16 pm: |
well my bad.. i meant i'm going to be using this set up for my music as well as a home theater. that's why the cd changer. any reviews abt C75ES???
