Home > Message Board > Home Theater > Bragging Area > Running Two Subs
Author Thread: Running Two Subs
Username: Movie_collector
, California
U.s
Post Number: 13
Ever thought of adding a second Sub?. Depending on your type of system, you may want to concider it. It made the difference with mine. Upload
UploadUploadUpload
Relevant Product Info
Username: Dmitchell
Post Number: 24
I'm running two subs in my system as well. I found it filled in the bass quite nicely, made it seem less directional.
I notice you are using a cable with dual inputs connecting your sub. Does this make any difference?
What do you think of the Def Tech sub?
Username: Illuminator
Post Number: 4990
Yeah, it evens out the direction, it's nice.
Username: Thx_3417
Bournemouth ...
Post Number: 3429
Yeah I run two subs in my home cinema granted I’d like each one to be the same but after doing a few test runs with a few special modifications where I use the 12” to low end from the LCR and surrounds with LFE.1 being run by a huge cinema JBL 18” JBL 4645 for LFE.1 only the blending of the low end gives good support without overwhelming the playback performance.
Three types of sound I’m looking out for is SLAM KICK and DEPTH!
Username: Davidpa
Portland, Oregon
US
Post Number: 443
Its the only way to go if you can afford it.
Username: Audiomakesmepoor
No the only way to go would be the velodyne DD1812. http://www.velodyne.com/velodyne/products/product.aspx?ID=3&sid=766s940d
Well i guess it kinda is 2 subs
Username: Velpo
Ventura, CA
US
Post Number: 11
My next purchase will most likely be a second sub.. do I just use a Y-cable to hook them up?
Username: Dmitchell
Ottawa, Ontario
Post Number: 270
Yup. That's all I did. I actually have a Y adapter plugged into the sub-out jack on my receiver, then I run a cable to each of my subs.
Username: Velpo
Ventura, CA
US
Post Number: 12
Cool, sounds easy enough.
I just hope the wife doesn't notice the second sub. :\
Username: Dmitchell
Ottawa, Ontario
Post Number: 272
Mine did...
Username: Apresler07
Canal Winchester, Ohio
Post Number: 53
Hahahahaha
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Bragging Area > Running Two Subs [ « Previous ] [ Next » ]
