Thread: Can someone give me a link to a good tv that is 1.3 HDMI |
Bronze Member Username: 1lakerfan
Post Number: 76 Registered: Apr-06
| Posted on Tuesday, February 27, 2007 - 01:42 pm: |
and tell me how 1.3 is better than the other ones |
Relevant Product Info
Gold Member Username: Hawk
Highlands Ranch,
CO
Post Number: 1215 Registered: Dec-03
| Posted on Tuesday, February 27, 2007 - 01:52 pm: |
1. None are out yet. 2. 1.3 has several advantages, the most important of which is what is called "deep color" best described here from the HDMI.org webpage: "With the launch of HDMI version 1.3, HDMI continues to increase its overall functionality to meet the needs of the High-Definition marketplace. HDMI 1.3 will include the following new features: Higher speed: HDMI 1.3 increases its single-link bandwidth from 165MHz (4.95 gigabits per second) to 340 MHz (10.2 Gbps) to support the demands of future high definition display devices, such as higher resolutions, Deep Color™ and high frame rates. In addition, built into the HDMI 1.3 specification is the technical foundation that will let future versions of HDMI reach significantly higher speeds. Deep Color™: HDMI 1.3 supports 30-bit, 36-bit and 48-bit (RGB or YCbCr) color depths, up from the 24-bit depths in previous versions of the HDMI specification. Lets HDTVs and other displays go from million of colors to billions of colors. Eliminates on-screen color banding, for smooth tonal transitions and subtle gradations between colors. Enables increased contrast ratio Can represent many times more shades of gray between black and white At 30-bit pixel depth, a four times improvement would be the minimum, and the typical improvement would be eight times or more. Broader color space: HDMI 1.3 removes all limits on color selection Next-generation “xvYCC” color space supports 1.8 times as many colors as existing HDTV signals Lets HDTVs display colors more accurately Enables displays with natural, vivid colors " I hope this answers your questions. |
Post Number: 77 Registered: Apr-06
| Posted on Tuesday, February 27, 2007 - 02:00 pm: |
Do you know when there supposed to come out |
Highlands Ranch,
CO
Post Number: 1218 Registered: Dec-03
| Posted on Tuesday, February 27, 2007 - 05:36 pm: |
HDMI 1.3 was only adopted last June, so it will take some time for the products to be designed, manufactured and delivered to the US. I would expect that you will see some product by the end of this summer. |
