Thread: Interference from subwoofer cable -- help please! |
New member Username: Muckydog
Post Number: 1 Registered: Feb-07
| Posted on Sunday, February 25, 2007 - 02:45 pm: |
I have a home theater setup with an NAD T762 receiver and a Sunfire Super Junior subwoofer. Whenever the subwoofer is connected to the system, I hear very loud interference when I turn on the system. The noise is fuzzy, but it sounds like I am picking up an FM radio station. I have tried to switch out the subwoofer cable and also to use a different subwoofer input on the receiver -- to no avail. It's not the subwoofer, because the noise occurs even if the the subwoofer is unplugged. The moment I pull out the cable, the noise goes away. Another strange fact -- the noise tends to subside (but doesn't go away entirely) 5 or 10 minutes after the system has been turned on. I would appreciate some advice -- this has been driving me crazy! Is there anything I can do to make this go away, other then doing without a subwoofer??? |
Relevant Product Info
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 1376 Registered: Feb-04
| Posted on Sunday, February 25, 2007 - 03:25 pm: |
Eric, this might help: http://www.sunfire.com/sub_faq.html#tech_q1 |
