Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through February 27, 2007 > Installing a ceiling mount prjector
Author Thread: Installing a ceiling mount prjector
Username: Murphdog
Sheboygan, Wi
United States
Is it tough to do or should you have a pro do it?
Relevant Product Info
Username: Eib_nation
Ohio
EIBville
Post Number: 152
IMO.....
If you have to ask the above question, you're probably not up to the task.
Username: Murphdog
Sheboygan, Wi
United States
that makes no sense.. Have you done it yourself?
Username: Davidpa
Portland, Oregon
US
Post Number: 400
Its easy if you have the right bracket. I did mine myself (two now) and it is not difficult at all. The second one I had help from the salesperson because he brought out the projector, and offered to help hang it. Just be sure to get all of your measurements down before the drilling begins, check the manual for heights, and distances and you'll be fine.
Also, be sure to hit the stud, but if you cant in certain spots, molly's work just fine as long as your projector doesn't weigh a ton.
Username: Murphdog
Sheboygan, Wi
United States
Post Number: 7
Thank you, I did recieve the bracket with the projector.
Username: Davidpa
Portland, Oregon
US
Post Number: 401
Keep us updated
Username: Gixer41960
Adelaide, South Australia
Post Number: 14
What projector are you mounting?
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through February 27, 2007 > Installing a ceiling mount prjector [ « Previous ] [ Next » ]
