Thread: BIG PROBLEM! please help |
New member Username: Roccostiffready
Post Number: 9 Registered: Jan-07
| Posted on Tuesday, February 20, 2007 - 05:50 pm: |
Recently I purchased the NAD T773 A/V receiver. The reason for the purchase is because all the composite, S-video and coaxial inputs on my TV do not work anymore. I got a quote to fix the TV at $700-800 and 3 to 4 weeks to fix. I figured invest the money into a receiver. When I try and connect my S/D bell receiver to the TV through the T773, I can see that the TV switches but it tells me it has a 525/60 signal. I can hear but I can not see anything. The TV is a Sony KE-42ts2u. I've played with settings on the receiver and the TV but I get nothing. Can anyone help me to get this to work? Thanks, Mark |
Relevant Product Info
Platinum Member Username: Project6
Post Number: 13048 Registered: Dec-03
| Posted on Tuesday, February 20, 2007 - 07:11 pm: |
Connect the Video output of the S/D Bell receiver directly to your TV and bypass the NAD. |
Post Number: 10 Registered: Jan-07
| Posted on Tuesday, February 20, 2007 - 09:02 pm: |
The composite, S-video and coaxial do not work om my TV. I tried the bell receiver on another TV and it worked fine. I think a maybe a setting in the TV or NAD receiver. |
Post Number: 13050 Registered: Dec-03
| Posted on Tuesday, February 20, 2007 - 09:51 pm: |
I tend to believe it is your TV as well. |
Bronze Member Username: Usernamex
London England
Post Number: 90 Registered: Oct-05
| Posted on Wednesday, February 21, 2007 - 06:16 am: |
Hey Mark, is the only input working on your tv is component? I guess you bought the receiver thinking it will convert the composite and s-video signals into component? Although most receivers do this these days, I believe the NAD T7x3 range (743, 753, 763, 773) don't do this! Actually, I've seen something they do sell... here it is, a separate box to do this job... http://207.228.230.231/info/NAD_TT1.pdf |
London England
Post Number: 91 Registered: Oct-05
| Posted on Wednesday, February 21, 2007 - 06:20 am: |
ouch that tt-1 is £249 at the one shop I found selling it... |
Gold Member Username: Arande2
400dB could probably d...,
SouthWest Mi...
Too Many DBs...
Post Number: 1632 Registered: Dec-06
New member Username: Hypersapian
Post Number: 1 Registered: Feb-07
| Posted on Sunday, February 25, 2007 - 11:51 am: |
I need some help....I put in new carpet, so I had to empty my living room. So, to make a long story short, I also changed from a VCR to a DVD/VCR combo. In doing so, my PS2 and XBOX with the PS2 multi-tap does not work. Did I do something wrong? Apparently , I did, but what? I have standard cable (no box), tv, stereo receiver, DVD/VCR combo, PS2, XBOX, and the multi-tap (which I used as a connector for the PS2 and the XBOX. Please help. |
