Thread: SONY DAVSB300 home theatre system |
New member Username: Digisol
Yeppoon,
Qld
Australia
Post Number: 1 Registered: Feb-07
| Posted on Friday, February 16, 2007 - 03:46 am: |
Anyone got a region free unlock code for the above DVD player, TIA to digisol@optusnet.com.au |
Relevant Product Info
Bronze Member Username: Usernamex
London England
Post Number: 82 Registered: Oct-05
| Posted on Monday, February 19, 2007 - 11:47 am: |
try here http://www.agoraquest.com/forum.php FYI, based on the two sony dvd's I've had, there is a remote code to enter a hidden engineering menu. Unfortunately, to change the region settings, both the dvd player needed a special sony engineer's remote. However, using a laptop's IR port, you can do the same thing with some free remore software. I think I may have found all this out at the above link. |
