Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through February 27, 2007 > New theater
Author Thread: New theater
Username: Murphdog
Sheboygan, Wi
United States
HI everyone,
Building a theater in my basement the room will be about 13w X 18 L. Any suggestions for equipment and how far on average is the projector from the screen? thanks
Relevant Product Info
Username: Arande2
400dB could probably d..., SouthWest Mi...
Too Many DBs...
Post Number: 1153
Budget comes first.
Username: Murphdog
Sheboygan, Wi
United States
not entry level but nothing extreme... More for sports and entertaining
Username: Tunasalad
California
US
Post Number: 83
Chase,
It is a lot easier to help you out when you give us lots of information. As I have learned, laying out a detailed budget will be important. Also, you need to decide what you want to get out of this system. There are probably four most important pieces of the system. So, first decide on a tv. A front projector is good, Sony makes great ones. I would think the projector would be about 8 feet away from the screen. The next thing is a receiver. Then are speakers, and a DVD and CD player. First, you need to decide on your budget and then decide on what you want to get out of the system.
Stefan
Username: Project6
Post Number: 12998
Chase,
What do you consider mid level or extreme for that matter?
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through February 27, 2007 > New theater [ « Previous ] [ Next » ]
