Thread: Speaker wiring |
New member Username: Scott_redinger
Erie,
PA
Post Number: 2 Registered: Feb-07
| Posted on Sunday, February 11, 2007 - 09:44 pm: |
I am not too experienced with running speaker wires so when I ran them in the bacement ceiling, I ran them right next to an existing electrical line because it was a convenient location. I don't believe the wire is shielded (typical 16 gage Radio Shack wire). Will this cause interference? Should I relocate the wires further from the electric line? |
Relevant Product Info
Gold Member Username: Arande2
400dB could probably d...,
SouthWest Mi...
Too Many DBs...
Post Number: 1136 Registered: Dec-06
| Posted on Sunday, February 11, 2007 - 09:56 pm: |
It would be a good idea. If you can't then you should still not run them side by side you should cross them perpedicular to each other like this + . |
Platinum Member Username: Project6
Post Number: 12909 Registered: Dec-03
| Posted on Sunday, February 11, 2007 - 11:59 pm: |
Yup, not a good idea to run them side by side. |
