Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through February 27, 2007 > Yamaha htr5740 need help installing c...
Author Thread: Yamaha htr5740 need help installing componets????
Username: Anthony303
Warren, Ohio
i bought a yamaha yht-755 includes the htr-5740 receiver and 5 disc dvd player. having difficulty installing everything(direct tv,dvd and surrond sound all together with monster htib home theater connection kit) into receiver and getting picture to big screen?help someone?? only temp fix until i get my plasma
Relevant Product Info
Username: Project6
Post Number: 12836
Connect the video sources directly to our TV.
Username: Project6
Post Number: 12837
oops, "your TV."
Warren, Ohio
dvd video component out to tv,dvd player audio out to av receiver audio in. direct tv receiver goes right to tv correct or into av receiver then what? and will work with theater unit??
Username: Project6
Post Number: 12843
1. Yes
2. Depends on the output of your direct TV. If it has video outputs, connect them to the TV and audio depends on the output. If it is stereo only, just go to the TV then from TV to receiver. If digital output then go to receiver.
Warren, Ohio
thanks berny,i'll try friday,if i have trouble i'll be posting you've been very helpfull
Username: Project6
Post Number: 12844
No worries.
Here's another help site if you need it
http://www.ceaconnectionsguide.com/
Username: Jbl_dude
try usding optical cables to hook up the dvd and the cable box, use components for the rest
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through February 27, 2007 > Yamaha htr5740 need help installing c... [ « Previous ] [ Next » ]
