Thread: Improve my system - NAD T753, Monitor Audio silver speakers |
Bronze Member Username: Usernamex
London England
Post Number: 56 Registered: Oct-05
| Posted on Sunday, February 04, 2007 - 09:45 am: |
I have… Receiver: NAD T753 receiver CD player: NAD T521bee DVD player: SONY DVPS735D Speakers: Monitor Audio silver s2, s1, and centre Stands: Atacama SE24 and SE40 (600mm and 1000mm) Rack: Sound Style WG3AV Set top box: HUMAX f2-Fox-T I bought the cd player when I had a prologic amp (NAD T753). I only use it now as a transport, do you think it's worth keeping? My old dvd won't play cdr's so maybe keep it just for that...? My speakers aren't bad, but I don't find my system them that convincing or completely engaging for music. I might be missing some bass perhaps. I can't really get a sub until I improve the floor sound insulation. My building was converted into flats in the 80's with no insulation apart from carpet. The flat now has laminate flooring with an ineffective felt sound barrier. Can't fix this until I've saved the cash for alterations and am ready to put down carpeting and some descent sound barrier. hmmm,... can speakers sound better at volume? ie not just sound louder, but better? info on speakers... "The C-CAM drivers,... use a ceramic coating applied to an aluminum/magnesium core that allows them to exploit the benefits of both substances (e.g., the rigidity of ceramics and the strength of metal)" S2 S2 Specification Frequency Response +/- 3dB 40Hz - 30KHz Sensitivity (1W@1M) 91dB Nominal Impedance(Ohms) 6 Power Handling RMS(W) 100 Drive Unit complement 1 x 7” C-CAM® Bass mid-range 1 x 1" (25mm) tweeter Bass Alignment 4th Order Reflex Ported External Dimensions mm (inch) 360H x 200W x 270D (14” x 8” x 10 ˝”) Weight 7.5Kg / 15lb Finishes Warm Beech Black Oak, Natural Oak or Rosemah |
Relevant Product Info
