Thread: Subwoofer Choice |
New member Username: Fransblm
Vancouver Canada
Post Number: 1 Registered: Mar-04
| Posted on Friday, February 02, 2007 - 06:13 pm: |
Looking for advice in choosing a sub. My room size is 11 by 12feet, w/ 8 ft ceilings. Walls are plaster/lathe, so acoustically it's quite nice. I have an Integra DTR6.4 receiver, paradigm mini's for fronts, paradigm cc-170 center, and paradigm ADP170 surrounds. Not sure if matching the sub with the rest of the speaker set is critical...opinions? |
Relevant Product Info
Platinum Member Username: Project6
Post Number: 12721 Registered: Dec-03
| Posted on Friday, February 02, 2007 - 06:21 pm: |
Not critical at all...what is your budget? |
Vancouver Canada
Post Number: 2 Registered: Mar-04
| Posted on Friday, February 02, 2007 - 06:30 pm: |
hmmm, let's say $200-$500 - a little limited. I've looked at some of the Velodynes, STS, and Outlaws. Also some used Paradigm PS 1000's with the idea that it would match the current config, but unsure if I want to take a risk on used speakers. |
Post Number: 12722 Registered: Dec-03
| Posted on Friday, February 02, 2007 - 06:52 pm: |
Take a look at HSU, they also make them for Outlaw. Velodyne would be my next choice. |
