Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through February 27, 2007 > Samsung HLS5088w
Author Thread: Samsung HLS5088w
Username: Coalie69
Willow Grove, PA
does the optical connection out on the back of the tv support dolby digital 5.1 If it doesn't, how would I sent dolby digital from my tv to receiver using a cable card.
Relevant Product Info
Username: Project6
Post Number: 12688
That depends on your source. A digital optical connection almost always carry 5.1, but if your cable comapny does not broadcast in 5.1 then you get digital stereo.
Do you have a cable box?
Username: Coalie69
Willow Grove, PA
no, I want to use the cable card
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through February 27, 2007 > Samsung HLS5088w [ « Previous ] [ Next » ]
