Thread: Amp for Polk speakers |
New member Username: Anujitd
Post Number: 2 Registered: Jan-07
| Posted on Friday, January 26, 2007 - 05:18 pm: |
Hi, Which of the 2 would be better suited to the Polk 5.1 M50, M30, CS1 and PSW10 ...Denon 1907 or onkyo 604? Also considering the fact that I am looking at clarity at medium -low volumes, do you think the Denon would be a better choice ? |
Platinum Member Username: Project6
Post Number: 12582 Registered: Dec-03
| Posted on Friday, January 26, 2007 - 06:06 pm: |
If those are the only options, I'd vote for the Denon. |
Post Number: 3 Registered: Jan-07
| Posted on Saturday, January 27, 2007 - 05:00 am: |
thanks Berny. In the similar price range, are there other amps which would be better suited? I have a 10' X 15' area. Movies / Music preference would be about 60:40 Thanks so much |
New member Username: Preposterouspresumption
| Posted on Sunday, January 28, 2007 - 01:07 pm: |
$500 is a decent price point for receivers. You have quite a few options. Is this an exclusive HT setup, or do you listen to Music as well? If so, what kind of music? |
