Thread: What is the best setup as a home theatre package for basement from VIDEO TO SPEAKERS to all ?? |
Bronze Member Username: Gigolo72
Post Number: 57 Registered: Jun-06
| Posted on Thursday, January 18, 2007 - 04:13 pm: |
Just about to start finishing my basement, but would like to know what will be the best theatre package to put after, BIG SCREEN OR PROJECTOR ?? any help is appreciated. |
Gold Member Username: Joe_c
Atlanta,
GA
Post Number: 1304 Registered: Mar-05
| Posted on Thursday, January 18, 2007 - 04:51 pm: |
What size is the room? what's your budget? how much percent wise movies vs. hd tv do you watch? How many people will you have down there most of the time? |
Gold Member Username: Nuck
Post Number: 5347 Registered: Dec-04
| Posted on Thursday, January 18, 2007 - 04:58 pm: |
How do you like your music? At all? |
Silver Member Username: Davidpa
Portland,
Oregon
US
Post Number: 295 Registered: Nov-05
| Posted on Thursday, January 18, 2007 - 05:08 pm: |
how dark can you get it? can you recess screen, or paint a wall if going projector route? How much can you spend on a plasma, or LCD? So many more questions? I can give some advise being I have rear projection downstairs, plasma and front projector in main room, and LCD in Master Bdrm, might be of some help. Plus Im always "shopping", and everyone I know comes to me before hitting the stores! Budget will eliminate quite a few options, or open up a few, I'll try to stay tuned. |
Atlanta,
GA
Post Number: 1309 Registered: Mar-05
| Posted on Thursday, January 18, 2007 - 05:19 pm: |
how do you like your eggs? one lump or two in your coffee? blonde or brunette? these are all important questions we need to know before giving you any advice on electronics. |
