Thread: Loose connection destroying my sanity! |
Bronze Member Username: Theymademedoit
Bristol UK
Post Number: 22 Registered: Jan-07
| Posted on Wednesday, January 17, 2007 - 10:32 am: |
Hi, I have a Technics seperates system and I have a right and left RCA lead going into the amp with the other end going into my DVD player in order to allow a bit more volume when watching DVD's. I had not used it for a few weeks and when I plugged it all back in there is hardly any sound coming out of the speakers, but if I wiggle and move the RCA lead at the amp, the sound is full, I then have to strategically twist and place them and creep away from the unit to keep the sound! The next time I turn it on I have to do it again!!!! Anay ideas what I can do or what is causing it? Regards, Alan |
Bronze Member Username: Mvanmeter
KY
Post Number: 79 Registered: Jan-06
| Posted on Thursday, January 18, 2007 - 09:25 am: |
the very thin wires in your cables do break with usage and age.... Splurge a little, spend $5 and get a new set of audio cables |
