Thread: Speaker/Amplifier Wattage |
New member Username: K40air
Post Number: 1 Registered: Jan-07
| Posted on Tuesday, January 16, 2007 - 06:15 pm: |
I recently purchased the Klipsch RB-81 bookshelf speakers, which are rated at (150W RMS / 600W Peak) After installing them I have been told that I am not sending them ample power. I matched them with the Yamaha HTR-6090 that does (120W x 7). Is this true that my speakers RMS power should be less than my recievers output? I have seen instances in which people say at least half! I am considering going to a smaller speaker if this is the fact. Am I getting two involved with the wattage from the reciever to the RMS power of the speaker. I don't want to hurt the reciever. Suggestions |
Gold Member Username: Joe_c
Atlanta,
GA
Post Number: 1297 Registered: Mar-05
| Posted on Tuesday, January 16, 2007 - 07:26 pm: |
"Am I getting two involved with the wattage from the reciever to the RMS power of the speaker. " Yep. I would just enjoy the sound and if it doesn't sound good, replace it. |
Platinum Member Username: Project6
Post Number: 12440 Registered: Dec-03
| Posted on Tuesday, January 16, 2007 - 09:54 pm: |
I second that. Who told you that you are not sending them ample power? |
Post Number: 2 Registered: Jan-07
| Posted on Wednesday, January 17, 2007 - 10:18 am: |
Friends, then i read up about it on the internet and the consensus was that you should have more wattage going to the speaker as the speaker would just clipp the extra power if it was too much. Everything sounds great but i wonder if i went down a speaker size would the amp drive it more |
