Thread: Help With Speakers |
New member Username: Camera_guy
North Bellmore,
New York
Post Number: 2 Registered: Jan-07
| Posted on Monday, January 15, 2007 - 09:26 pm: |
I have a Sony Bravia KDL-40V2500, a Scientific Atlantic 4200 HD cable box, an Onkyo TX-SR703B Receiver!! I was able to get everything working one problem though when I have on HDTV the Sub Woofer Front Right, Center and Rear Right work if I switch to XM Satellite all speakers work I never got around to hook up the surround speakers yet it is hooked up 5.1 it is 7.1 any ideas???? much appreciated |
North Bellmore,
New York
Post Number: 3 Registered: Jan-07
| Posted on Tuesday, January 16, 2007 - 10:51 am: |
I just got finished hooking up the other surround speakers! still have the same problem! only three speakers are working but yet if I put the Tuner on all seven speakers play |
Platinum Member Username: Project6
Post Number: 12431 Registered: Dec-03
| Posted on Tuesday, January 16, 2007 - 11:00 am: |
Are you using a digital connection to the receiver? Make sure that the receiver is also on "Auto Detect". |
North Bellmore,
New York
Post Number: 4 Registered: Jan-07
| Posted on Tuesday, January 16, 2007 - 01:17 pm: |
Are you using a digital connection to the receiver? Make sure that the receiver is also on "Auto Detect". Thanks for the reply!! I have it working now! |
