Thread: Harmon Kardon 145 - good enough? |
New member Username: Expatcanuck
Post Number: 5 Registered: Dec-06
| Posted on Monday, January 15, 2007 - 05:07 pm: |
Greetings. We're getting a 40" flatscreen, and want to hook up surround sound. It's a smallish room, roughly 10' x 12'. Third floor condo - we don't need theatre volumes, and 5.1 surround should be fine. The final decision hasn't been made, but I suspect we'll be driving Paradigm Atom speakers which, per Paradigm's website http://www.paradigm.com/website/SiteParadigmProduct/ParadigmModels/Performance/P erformanceSpecs.htm are okay with 15-80 watts/side. It'll be those or something comparable. I'm looking at the Harmon-Kardon AVR 145 receiver, which sports 40 watts / channel in surround mode (into 8 ohms -- no specs for 4 ohms). Perhaps not a visually aesthetic treat, but at $300/new, perhaps it's good enough. Any reasons why I might not want to get it? I could spend up to $500 for an Onkyo 703 or a NAD T743 (I rather like our 320BEE), if the money's buying something worthwhile. All thoughts welcome. - Richard |
Platinum Member Username: Project6
Post Number: 12432 Registered: Dec-03
| Posted on Tuesday, January 16, 2007 - 11:09 am: |
That is a great receiver and much better power supply than the Onkyo. However, if you are fond of your BEE, there is nothing you will not like about the T743. I believe it is something very worthwhile |
