Thread: 1080i vs 720p |
Bronze Member Username: Tunasalad
California
US
Post Number: 23 Registered: Dec-05
| Posted on Sunday, December 31, 2006 - 07:42 pm: |
Hi Everyone, I was playing Xbox 360 on my HDTV and I was wondering, at what resolution should I output the video signal, 1080i or 720p? I heard somewhere that the progressive scan will get me better picture, even with a lower res. Is this true? Thanks for any and all help and Happy New Year. Thanks, Stefan |
Silver Member Username: Camaro823
British Colu...
Post Number: 900 Registered: Jun-05
| Posted on Monday, January 01, 2007 - 02:34 am: |
Sorry I can't answer your questions, but this revolves around what i'm struggling with, how do you set the signal ? where is this option between 1080i and 720p ? |
California
US
Post Number: 24 Registered: Dec-05
| Posted on Monday, January 01, 2007 - 03:43 am: |
Hey JC, to set the output, turn on your 360 on with no game in it and use the menu to go to the systems tab, then select video options. From there, you can select the appropriate setting. Stefan |
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 1255 Registered: Feb-04
| Posted on Monday, January 01, 2007 - 12:47 pm: |
You set the resolution according to the number of hobbits native to your HDTV.
.....or the number of oompa-loompas in your TV. You decide.
California
US
Post Number: 25 Registered: Dec-05
| Posted on Monday, January 01, 2007 - 01:10 pm: |
John, That was the most interesting thing that I've had explained to me in a long time. It was very helpful. Was that your creation, or if not, where did you find it? Thanks, Stefan |
Columbus,
Ohio
US
Post Number: 1256 Registered: Feb-04
| Posted on Monday, January 01, 2007 - 02:25 pm: |
Stefan, I hope you didn't take my post the wrong way. I wasn't making light of your question---it's just that this subject has been debated countless times, both on this forum and elsewhere on the net. You only need Google "1080i vs 720p" and see. That's how I found this: http://neopoleon.com/home/blogs/neo/archive/2005/12/06/18198.aspx |
British Colu...
Post Number: 901 Registered: Jun-05
| Posted on Monday, January 01, 2007 - 04:09 pm: |
Thanks Stefan |
California
US
Post Number: 26 Registered: Dec-05
| Posted on Monday, January 01, 2007 - 05:26 pm: |
John, I'm sorry that you thought that I was being sarcastic. I was genuinely helped by your post. I wish there was a way to convey my sincerity. All I can say is I am continually grateful for your help. Thanks, Stefan |
New member Username: Roger_ramjet
Post Number: 9 Registered: Nov-06
| Posted on Tuesday, January 09, 2007 - 07:06 pm: |
If you want to setup your 360 properly for your display...you just need to find out the native resolution of your display. Mine is 790P, so I set my Oppo for 790P...if it was 1080i, I would set my Oppo to 1080i. That way the display doesn't have to do any converting. At least thats how it works with my HDMI signal. Otherwise...just use your eyes...and decide if one looks better than the other. I don't think it's a matter of which one is better...it's what your display is made to produce. Cheers, Ray |
