Home > Message Board > Home Theater > Home Theater Computers > Media center pc
Author Thread: Media center pc
Username: Cammeyer
How do I connect my PS3 to my media center pc.
I want to know because my tv sucks
Relevant Product Info
Username: Arande2
400dB could probably d..., 4000 isnt ev...
100,000dB FU...
Post Number: 463
Ok I tried to connect my game console to my pc and the quality wasn't great. I'm not sure what caused it though. Well on the back there should be an S-video input and possibly a Dvi input on the nicer models. You just need to make sure your cable has S-video connectivity and digital audio if your computer has the input. It's rather simple. Then you go to the control panel of your computer and set that video input, which I'm not quite sure how to do yet.
Username: Cammeyer
ok thanks i will try it
Username: Arande2
100,000dB FU...
Post Number: 466
Ok, just keep in mind that I had very bad image quality hooking my Xbox up to my comp using S-Video, I mean bad, it was slow, and sluggish. If you computer monitor has a straight S-video input or something like that it'll be way better.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Home Theater Computers > Media center pc [ « Previous ] [ Next » ]
