Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 20, 2007 > Help with set up of components please
Author Thread: Help with set up of components please
Username: Nightmagic
Regina, Saskatchewan
I need help to set up my home theatre system. I have an amp, cable box (1 HDMI hook up), DVD recorder/VCR combo (1 HDMI hook up), and an LCD flatscreen TV (1 HDMI hook up).
I would like to be able to record on the DVD player on all chanels while watching other chanels. I would be so grateful if someone could help me.
Username: Arande2
400dB could probably d..., 4000 isnt ev...
100,000dB FU...
Post Number: 190
I don't know what you mean by amp. By hook up do you mean input and output? Could you please explain your setup a little bit more?
Username: Derekh
Hi can you help need to get Tv to play sound through Sony HT-SF1000 theatre system DVD's work but no sound from TV what am I missing please
Username: Arande2
100,000dB FU...
Post Number: 192
I'm assuming you mean you're wanting to watch TV broadcasts.
All you need to do is hook the fixed audio outputs of your TV to an audio input of the receiver.
Thanks for the help
My system includes an onkio 7.1 reciever (Amp), A Toshiba LCD flat pannel TV , a DVD recorder/ VCR combo and a cable box. I can use the DVD recorder to play movies etc. but I am having trouble getting it to record through the cable box rather than through the incoming antenna from the wall.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 20, 2007 > Help with set up of components please [ « Previous ] [ Next » ]
