Thread: Help in hooking up theater in a box |
Bronze Member Username: Burtshell
Boynton beach,
FL
United States
Post Number: 13 Registered: Nov-04
| Posted on Wednesday, December 06, 2006 - 12:43 pm: |
i have the following components: panasonic hdtv tv. scientific atlanta hdtv explorer 8300 hd cable box. sony hdtv dvd player. these components are hooked up as follows: cable box-cable in from wall. cable box out to tv with hdmi cable. sony dvd player out to tv with hdmi cable. everything works. now if and when i purchase a theater in the box,how do i hook up the receiver? do i just connect the dvd player to the receiver? does anything else have to be connected to the tv? i am aware of the wiring for the speakers. please advise. thanks burtshell |
Platinum Member Username: Project6
Post Number: 11769 Registered: Dec-03
| Posted on Wednesday, December 06, 2006 - 05:39 pm: |
Wait until you purchase the receiver. Once you have it, read the manual first. If you still encounter some trouble, re-state a more specific inquiry. I'm sure you can hook it up with no problem. |
Post Number: 11770 Registered: Dec-03
| Posted on Wednesday, December 06, 2006 - 05:41 pm: |
Try this one too http://www.ceaconnectionsguide.com/ |
