Thread: Cheapest place to by Klipsch speakers? |
New member Username: Sammy0630
Post Number: 1 Registered: Dec-06
| Posted on Saturday, December 02, 2006 - 01:56 am: |
Hi all, I'm planning to buy Klipsch home theater speakers pretty soon. I've been to Best Buy a couple of times but I was not sure if their prices are reasonable because I got ripped off once from them. Can anyone recommend a place that I can buy Klipsch cheaper than probably Best Buy? Thanks. |
Platinum Member Username: Project6
Post Number: 11699 Registered: Dec-03
| Posted on Saturday, December 02, 2006 - 02:19 am: |
Go to the Klipsch website and you can search for an authorized dealer closest to you. |
Post Number: 2 Registered: Dec-06
| Posted on Saturday, December 02, 2006 - 02:26 am: |
I live in Morgantown, WV and the nearest one is Best Buy, which I'm not sure if I'm not getting ripped off. I'm thinking to buy it on the web. |
Post Number: 11739 Registered: Dec-03
| Posted on Tuesday, December 05, 2006 - 12:08 pm: |
They have some pretty competetive prices, but you can definitely shop online but you also have to worry about shipping charges. |
New member Username: Davina_007
Post Number: 7 Registered: Dec-06
| Posted on Tuesday, December 05, 2006 - 03:38 pm: |
online would be the best bet...I have a Klipsch sub I picked up from a local dealer in South Texas and paid about $100 more than it was online. I just preferred to have a local dealer to deal with in the event of problems. |
Silver Member Username: Divin11112000
Michigan
Post Number: 115 Registered: Dec-04
| Posted on Thursday, December 07, 2006 - 12:36 pm: |
If your going to buy Klipsch online be sure you check out the Klipsch website. You have to buy from an authorized dealer or you won't receive any warranty on the product you buy |
