Home > Message Board > Home Theater > Home Theater in a Box > Archive through December 29, 2006 > Turning up volume without sound
Author Thread: Turning up volume without sound
Username: Adrwcav
I wanted to know the max volume of my Bose 321 system so i turned up the volume all the way on the Aux. channel so the actual TV sound wouldn't come out. As the volume increased so did a slight buzzing noise in the speakers. Is this bad for the speakers or sub???
Thanks for the help.
Username: Project6
Post Number: 11675
Not really.
Username: Adrwcav
Thanks...you don't happen to know exactley what is happening when i did this though?
Thanks for the help
Username: Project6
Post Number: 11692
One of the things that can cause a buzzing sound aside from a faulty unit would be ground issues, improperly connected cables or bad cables.
Home > Message Board > Home Theater > Home Theater in a Box > Archive through December 29, 2006 > Turning up volume without sound [ « Previous ] [ Next » ]
