Thread: Help/advice required for amp connected to pc. |
New member Username: Davidhue
Post Number: 3 Registered: Nov-06
| Posted on Thursday, November 16, 2006 - 06:52 pm: |
hi, i am new to these forums.would appreciate any help or advice on how to get the best sound possible for playing media(music/dvd/film/tv) through my pc.i currently have an integratd amp(marantz pm7200) and 4 pretty good quality speakers(not surround sound)connected to my pc,my soundcard being the creative audigy 2 zs.is there a better way to improve things even more eg a top of the range soundcard/a surround sound receiver/speakers instead of an integrated amp etc? any help would be appreciated. thank you. |
Platinum Member Username: Project6
Post Number: 11567 Registered: Dec-03
| Posted on Wednesday, November 22, 2006 - 04:17 pm: |
What speakers are you currently using? |
Post Number: 4 Registered: Nov-06
| Posted on Wednesday, November 22, 2006 - 05:46 pm: |
hi,thanks for the reply.i have just bought a pair of acoustic energy aelite 2s.my other pair are older and less powerful(kef coda 70s) but i am going to upgrade very soon.hope this helps. cheers. |
Post Number: 11578 Registered: Dec-03
| Posted on Wednesday, November 22, 2006 - 07:03 pm: |
Very nice speakers. How are you connected to the receiver? What do you feel is the system lacking, soundwise? |
Post Number: 5 Registered: Nov-06
| Posted on Wednesday, November 22, 2006 - 08:28 pm: |
hi , i just have a simple thx monster cable from the out socket in the soundcard going into the cd out on the amp.the sound is fine i suppose (although i notice that sound is louder and clearer playing music than when playing dvd), just looking to upgrade further but not sure which department to foucus on.do you have any idea on what will influence the sound more in my set up: the soundcard ,amp or speakers? or is it a combination of all of them.i'd also like your opinion on wheather i should stick to an int.amp or opt for a surround sound receiver and speakers(would it make much differance?) many thanks. |
Post Number: 11584 Registered: Dec-03
| Posted on Thursday, November 23, 2006 - 01:34 am: |
"going into the cd out on the amp"???? Explain this connection. |
Silver Member Username: Leew
jennifer contreras® ,
Yokosuka, ...
SPESNAZ. ...
Post Number: 877 Registered: Jan-06
| Posted on Thursday, November 23, 2006 - 04:19 pm: |
maybe he have to connect his CD or DVD Rom from "audio out" to the sound card with digital cable (two pin) I use it from comp. to receiver "S/PDIF-Out(optical cable)"! |
Post Number: 6 Registered: Nov-06
| Posted on Thursday, November 23, 2006 - 04:55 pm: |
hi , with regards to berny's query ,the cable is 2 pin going into the left and right channel of the cd-r/md out sockets on the rear of the marantz amp.i can also have them in the tape out channel and one of my aux channels(i have aux 1 and 2).the sound is the same in all 3 connections. cheers. |
Post Number: 11594 Registered: Dec-03
| Posted on Thursday, November 23, 2006 - 05:49 pm: |
Are you set on using the PC as your entertainment system? If you are, you may want to look into a better soundcard. You may also want to stay away form compressed music formats, they do not sound that great. |
Post Number: 7 Registered: Nov-06
| Posted on Thursday, November 23, 2006 - 05:56 pm: |
yeah , i am set on the pc .space is an issue and i am getting a new 32" lcd tv at xmas and i intend connecting that to the pc and kill 2 birds with the 1 stone: tv watching etc. and pc use.do you reckon the soundcard is the main factor to enhance my sound further? |
Post Number: 11595 Registered: Dec-03
| Posted on Thursday, November 23, 2006 - 06:04 pm: |
The sound card and your music format. |
Post Number: 8 Registered: Nov-06
| Posted on Thursday, November 23, 2006 - 06:06 pm: |
ok, thanks for your help. |
